I have some problem when use rear camera will stop sound from any apps.
@Modern Surawut many people is claiming about this....perhaps is a bug of the ROM you have installed.
There is an specific setting (under car settings) for this....check this if solved...if not could be a ROM bug
@Modern Surawut solved in latest vivid ROM:
Vivid 11 Version Make Sure your unit is PX6 Android 11
telenav_vivid_rk3399_11.0_ota(20230107)
https://www.dropbox.com/s/cbs1abtvzfgch49/telenav_vivid_rk3399_11.0_ota%2820230107%29.zip?dl=0
@Modern Surawut please send feedback if the problem is solved
How it is solved? could you go higher then -6db when reversing in Vivid 11?
@Martin Kolembar The last avilable updates (VIvid & Scout) fixed the no sound during reverse (independently on the volume atteanuation option) . on Settings/Car Settings you can adjust the volume attenuation whle on reverse.. i dont remeber how the scale is established...
