@Al Ferro
You are welcome😀
@Al Ferro
You are welcome😀
@Support Dasaita : Can you please post the release notes for zst27_sc138_12_(20241126) ?
@Kamal Grover
Hi Kamal,
Here is the firmware forum for your referece:
https://www.dasaita.com/community/forum/topic/125448/firmware
Hi. I have a Nissan Qashqai 2017 with Dasaita vivid 11 with the last update. Cameras work properly while the software is loading, after that image disapear. CarPlay works ok but without images to park, sound radar works. I can't get the steering wheel controls to work either. What should I do? Is it an MCU problem or something? Thanks
Hi everyone. I have a 2017 Qashqai and a Max11. With the latest software version listed on the page. The cameras work properly while the software is loading. Afterwards CarPlay works properly, but the images disappear when parking. Only the lines, dark screen and radar sounds It seems that the software cannot manage the cameras. I also cannot control the device from the steering wheel. What should I do? Do I need to update the MC Uo something like that? Thanks
Is the MCU MTCH_HA4Z for the G12 units and the MTCHS_HA4Z for the G13 units?
What is the difference between these 2 MCUs?
Regards.
Hi, can you please post the changelog for the G12 20241126 firmware? Thanks in advance
How to change logo with the Toyota instead of Dasaita at the start of the radio ? I have the PX6 Vivid 10 Version (lastest firmware January 2024)
thanks
@Support Dasaita Hi again, i am wondering if there is an update to File-Vivid13(20240702) you provided to me around 5 months ago!
I can't do the latest update on my g12. I keep getting that error 7. Is there a previous update that would work? Or how do I fix that error. I got the beta to update but it's super buggy. Help
I need this version again I updated now I have black screen an tail lights don't work
@Nick M
Please check the update tutorial below and give it a shot.
System Firmware-G12-20241126:
MCU-4.12b:
@Juan Guzman
Regarding to your issue, we suggest that you can firstly try to use a Pin/Paperclip to press and hold the RST Button for 15 seconds to enter the recovery interface to do the factory reset.
In order to help you better, please provide the following information if possible:
Pictures: Settings > About Machine > Android Version; Build Number; MCU version.
@Support Dasaita this is the version I need that came with the radio from Amazon I upgraded firmware an it went crazy an need to go back to original .
