PX6, Honda Civic 2009 Issues. Help!
  • Hi there,
    I have on-going issues with my PX6, installed in a 2009 Honda Civic. The screen is often heavily distorted, making the graphics look washed out and strangely warped. Occasionally, it will correct itself and look normal but it usually takes a bit of warming up/driving for this to happen.
    The touchscreen is often unresponsive and audio through CarPlay will frequently stop playing...which only returns when I switch to the radio for an extended period of time. My back camera is also intermittent. I have no idea if my unit is just faulty or if it is a electrical issue with my car, as I installed this unit myself.
    If you could please advise, I’d greatly appreciate any help you can offer. The device is running the latest MCU V3.78_1 and the latest supported version of Android 10.
    Many thanks!
    James.
  • Hi
    please go factory setting put password hcttest253
    and restart the unit , and will will come back to normal
  • @Quick Yuan
    Hi there.
    I did as you suggested...but it has made the issue worse.
    It hasn't fixed the display and it's messed up the resolution. The touchscreen is also now not working properly. When I try and tap somewhere, it thinks I've tapped somewhere else.
  • sorry that do not your unit details  . your unit is 1024*600 resoluctions
    https://www.dropbox.com/s/gwzqzocvnr6rj1n/dmcu.ext?dl=0
    download this file , copy to a empty USB disk (format before use ) . plug to the USB cable
    after you see the screen come out numer 2
    power off and restart the unit
  • Thank you.
    That restored the resolution perfectly.
    Unfortunatley, the screen is still distorted, even after the 'hcttest253' factory reset. Any other suggestions on how to fix this?
    Thanks,
    James.
  • @James Newman type   hcttest242 , is use for unit with  1024*600 resoluctions screen
  • @Quick Yuan
    After entering the code and restarting, it made no difference 😭. The screen is still distorted/warped.
    Could this potentially be an issue with the power my car is supplying to the device? Do I need an additional device, something to regulate the battery power?
    Or could my unit just be faulty? Hopefully not!
    Thanks,
    James.
  • @Quick Yuan
